Broaddict
Small Member
Hi guys!
We have prepared a brand new product - Broaddict Pinch Weld Cover specifically designed to protect the rocker panel area under your Bronco's doors.
Know more:
Broaddict Pinch Weld Cover 2dr
Broaddict Pinch Weld Cover 4dr
These pinch weld covers offer a range of benefits, providing protection to your rocker panel area while hiding unsightly steel plate welds and rust. Let's delve into the details:
Compatibility
Our pinch weld covers are specifically designed for Ford Bronco from 2021 to 2024. This ensures a perfect fit that seamlessly integrates with the design of your Bronco.
Rust and corrosion resistance
Our pinch weld covers are made from high-quality aluminum, ensuring durability. They are treated with a black powder coating on the surface, not only enhancing the aesthetics but also providing excellent rust, corrosion, and waterproof properties.
Hiding unsightly welds and rust
When you remove the rocker panels or install certain styles of pedals, the weld seams underneath the body will be exposed, affecting the overall appearance of your Bronco. By installing our pinch weld covers, you can easily hide these unsightly welds and any existing rust, greatly enhancing the visual appeal of your Bronco.
Protection for the pedal area beneath the doors
Our pinch weld covers not only hide imperfections but also protect the pedal area beneath the doors. Whether it's debris, scratches on the road, or other potential damage, these covers act as a barrier to protect your Bronco, ensuring it remains in pristine condition.
Easy bolt-on installation
We understand the importance of a simple installation process, which is why our pinch weld covers feature an easy-to-install bolt-on design. Utilizing the existing holes on your Bronco, you simply need to tighten the screws to install the covers. This ensures a secure and reliable installation, allowing you to enjoy the benefits of our product without complex steps.
Thank you for watching.
Know more:
Compatibility
