ICON has announced their first 2021 Bronco Specific product!
The ICON Leveling Lift Kit for 2021 and newer Ford Bronco provides an easy to install, economical yet performance-enhancing method of gaining the necessary clearance to run larger tires. The kit consists of CNC machined 6061 billet aluminum top spacers and pre-load adjusters to yield approximately 3” of front suspension lift and 2” of rear lift to level the vehicle’s stance. The result is full articulation, full steering range, no-rub fitment for up to 35” tires on non-Sasquatch equipped Broncos or up to 37” tires if Sasquatch-equipped. ICON engineers have dialed in the dimensions to tuck the tires cleanly into the OE fender flares at full bump (up travel) when using either factory Sasquatch wheels or 17 X 8.5, 25mm offset wheels such as the amazing ICON Rebound Pro. The components are relatively easy to install without disassembling the shock itself (spring compressor required for installation on some models). Get the most travel and articulation possible out of your factory control arms without ball joint bind or over-extension. Hit the trail with the confidence of knowing your suspension components are covered by ICON’s Limited Lifetime Warranty.
Photo below shows the kit installed on a 2-door Base Bronco, non-Sasquatch, at full suspension compression (the coil springs were removed from the struts to allow full compression while checking clearance). The Bronco in the photo was equipped with 25x12.50-17LT Nitto Trail Grapplers mounted on ICON Alloys 17X8.5 Rebound wheels with 25mm offset. With this combination the tires tuck cleanly into the non-Sasquatch flares at full compression, with no rubbing and full steering range.
This photo shows the same setup at full suspension extension, again with coil springs removed to allow free movement of the suspension components, showing the full range of travel using the stock upper and lower control arms.
The kit may be used on all models of 2021 Ford Bronco, to fit 35's on non-Sasquatch Broncos or 37's on Sasquatch-equipped Broncos. MSRP is $419, with most authorized ICON Dealers using our MAP price of $399. Orders may be placed now, for fulfillment beginning in a couple of weeks as the first production run is still underway. Available Direct from ICON or from any Authorized ICON Dealer (inquire by phone or email if your dealer of choice doesn't have it listed yet, as they have already received data and are able to place orders even if they haven't loaded it into their website yet).
[Dislcaimer: as some of you know, I work for ICON Vehicle Dynamics. I'm posting this in my capacity as a rep for ICON.]
