charleskh
I figure the F150 of this era is pretty close to an FSB..
Backstory: I ended up having to sell the last Bronco I built back in 2015. Was moving around the country a lot the last 10 years, ended up buying the F150 from a guy in Charlottesville, VA in 2017. Since then I've made it back to CA as of 2019 and spent most of that time keeping the truck on the road/maintenance as it was my only vehicle for awhile. Finally was able to rent a house with a garage and room for all of my tools and get more serious with it, got it to pass CA smog and now I'm gathering parts/saving up money for the 1-ton swap.
Started with:
1978 F150 4X4 Custom, Regular cab, Short bed (Federal emissions)
Next-up:
Started with:
- 351M - Edelbrock 4 barrel intake, Holley 4-barrel 600cfm, long-tube headers, and ratty dual Flowmaster exhaust.
- C6/NP205.
- Stock axles - D44 hi-pinion/9-inch. 3.50 gears.
- Unknown leveling kit/cobbled, busted leaf-kit.
- 31" all-terrains.
- SandJEngines.com remanufactured 400 - stock 2 barrel intake and 2150 carburetor with all emissions set-up and passing smog (EGR and all that vacuum crap). 3G alternator, MK VIII fan with autocoolguy.com controller, Champion 3-core aluminum radiator
- Rebuilt C6/NP205
- Stock axles rebuilt
- Superlift 1-2" coil springs/Deaver 4" 10-leaf pack (H57) with the factory lift-block removed.
- 33" BFG KM3's
- Bilstein 5100 shocks
- Other stuff - Lund Toolbox, Viair 76CFM air compressor, Vintage Air AC
Next-up:
- 1-ton axles - F350 Dana 60/Sterling 10.5 with factory e-locker, 3.73 gears, WFO radius arms with Metalcloak bushings, 37" BFG KM3 and Procomp 17x9's
- Hydroboost
- Hydraulic-assist steering
