Oldbronc
I purchased this Bronco in 98 and got a lot of things fixed early on then took It to Glamis dunes and other trips. In 2019 I decided not to get another side by side and instead do a major overhaul of this old girl. New stroker 347 with Holley fuel injection, Flowtek heads full roller motor.
C4 Dana 20 Tom woods drive shaft, lockers front and rear, rebuild drivetrain rebuild Dana 44. New 23 gal fuel tank with in tank Hyperfuel pump. New Brakes new lines 77 disc conversion knuckle over tie rod and track bar riser, radius arm drop brackets and C bushings to achieve 6 degrees caster. Limit straps to stop from drive shaft bind. Wild Horses 5.5 lift, 15x8.5 Copper Discoverer SST 35's. Amp steps.
